Arduino Rotary Table for Dummies
Well, here goes. I built a rotary table some time back, and by following all the excellent instructions here managed to get it to work quite well. A few weeks ago I decided to make a larger version and this is where it all came a gutzer. I purchased a NEMA 23 hybrid stepper motor and 57HS76ES controller, decided to make it closed loop for greater accuracy. Mounted the motor to the table ( 6 inch Vertex knock off, AU$215 delivered, still can't believe it!). I connected it to the Arduino Uno, used the same connections as before but with the additional encoder as well. 24 volt supply. Nothing happened. 24 volt supply, 0.5 amps and the motor was locked solid.
Pulled everything apart, connected the old TB6560 driver but without the encoder wired in, worked perfectly. I decided that the 57 controller might be the problem. In my ratty box I had a new TB6600 Stepper driver, I think this is just a bigger version of the 6560 more current etc, but when I wired it in the same result, nothing. 24 volt supply, 0.17 amps, motor locked.
I have spent one of the most frustrating days of my life with this, I think that I have checked everything I can think of. I don't pretend to be a genius at this stuff but I didn't think I was as stupid as I feel now. Photos that may help, please couch replies as you would to a four year old, right now I don't think I'm even at that level. Cheers, Peter.
Peter
You can make almost anything work and I am happy to help you. I have helped many people sucessfully with this project over the last couple of years. The original Arduino sketch would only work for 90 to 1. All other ratios were inaccurate because the sketch used integers rather than real's. This means that if the divider was 44.44444 everything past the decimal point was ignored and hence the errors.
Send me an email to [email protected] and let's get it working for you.
Bruce
I thought this point had been raised before and the original author answered the question with a satisfactory solution.
Bruce, many thanks for your offer to help, I will contact you later today. Xpylonracer, I would be grateful if you could point me in the right direction to the satisfactory solution in this post. I have read all 21 pages through at least twice and still cannot find the reason why the drivers behave differently. Thank you for your post. Cheers, Peter.
snip
snip
Hmmmmmmmm - - - - I'd be curious as to where you found that 'table' - - - please?
Peter, read from here onwards:
Electronic Dividing Head using the Arduino
Here is the link to the table: Rotary Table (Horizontal & vertical ) 150mm/6" | eBay
The quality seems OK to me but I haven't stripped it down. I have a Vertex 4" (Taiwan) as well and this looks just as good. One day I may just get to use it if ever I sort out these other problems.
Peter.
Went looking - - - - it seems that our Aussie friends have it much better than us here in the northern hemisphere.
Looked like same product was well over $500 Canuckistani buckeroos and that was without shipping from our cousins south of us - - - - which has become incredibly pricey.
Thanks for the link - - - - - gives me a starting point for looking!
If you do an eBay search with "rotary table HV6", I get the following link with the USA eBay site.
https://www.ebay.com/sch/i.html?_fr...t=0&LH_TitleDesc=0&_osacat=0&_odkw=HT6+rotary
So do you want a 4 slot or 3 slot (there are 6 slot tables available also). I sort on lowest price plus shipping. So you need to scroll down from the early hits (dividing plates and tailstocks), but you can find one from India for less then $200USD with free shipping.
Like this one;
https://www.ebay.com/itm/HV6-Rotary...612534?hash=item2f53c0e1b6:g:-zUAAOSwbLVfTMOe
However, I have a 4" table from India, and I do not like any part of it's poor quality. And my next purchase was a 6 inch that came from China, and again, substandard quality.
  • HV6 Rotary table 3 SLOTS Horizontal & Vertical Precision Quality.pdf
Hi....without basic literacy in Arduino you will find it hard to write a sketch to do much more than those examples.
Understand that you can lift sections from those sketches for your own, modify as needed but make sure that you know how they work and what they do which takes reading the lines, literacy. How much faster did grade school go for you once you could read books, write papers and do math?
You don't have to know everything, just the basics. Variables and arrays, logic structures, how to use and make functions, the input/output functions for pins and serial and know to look things up starting with the Arduino Reference Page.
I have managed to sort out most of the frustrating problems that I posted about above, they were due to a faulty power supply. I would like to thank those who helped, in particular Bruce Weir-Smith whose knowledge of Arduino and Steppers greatly exceeds mine. Bruce was kind enough to spend his time emailing me circuit diagrams and instructions that helped track down the problem.
I have taken the advice of Rodw where he maintains that 48 volts is the way to go and I have ordered a Meanwell 500 watt 48VDC power supply, any heat issues I will address as they appear. Cheers, Peter.
This is my prototype in C++. It features accumulated error management and regardless of the number of indexing divisions it goes 0 to 360º. My servo motor requires 2048 pulse per revolution so here's the logic:
Seconds in 360º: 1296000
My motor ppr: 2048
My gear ratio: 4:1 low backlash gear head * 90" rotary table gear ratio: 4 * 90 = 360:1
Motor ppr per rotary table revolution: 360 * 2048 ppr = 737280 pulse per rotary table revolution
1296000 / 737280 = 1.7578125 seconds per motor pulse (but we use degrees)
1 degree = 3600 seconds
3600 / 1.7578125 = 2048 The value of the variable, user in my code
(3600 / (1296000 / (motor ppr * gearing))) = user
degrees output are degrees = (degrees + (steps / user))
It does no good to compound (360º / divisions)
accumulated error output is error = (error + ((360º / divisions) - (steps / user)))
I moved up to the 32bit Arduino DUE so the double declaration is for real unlike the UNO that accepts double declaration but remains to be 16 bit. As you can see in the picture this builds and extremely accurate indexer. Picking up the fractional value of the steps keeps the accumulated error down to next to nothing.
C++:
// Visual Studio C++ 2019 w/round function
#include <process.h>
#include <iostream>
#include <fstream>
#include <iomanip>
#include <string>
int main()
    double error = 0;
    double steps = 0;
    double crumbs = 0;
    double divisor = 0;
    double degrees = 0;
    double index_L = 0;
    double user = 2048;
    std::cin >> divisor;
    index_L = (360.0 / divisor);
    std::ofstream myfile;
    myfile.open("Indexer.txt");
    std::cout << "\n";
    for (int n = 1; n <= divisor; n += 1)
        steps = ((index_L * user) + crumbs);
        crumbs = (steps - round(steps));
        steps = round(steps);
        degrees = (degrees + (steps / user));
        error = (error + (index_L - (steps / user)));
        std::cout << std::fixed;
        std::cout << "Index: " << n << ": - " << "Degrees: " << degrees << char(167) << " - Accumulated Error: " << std::setprecision(8) << error << char(167) << "\n";
        myfile << std::fixed;
        myfile << "Index: " << n << ": - " << "Degrees: " << degrees << "º - Accumulated Error: " << std::setprecision(8) << error << "º\n";
    myfile.close();
    std::cout << "\n";
    system("pause");
    return 0;
Yours looks like a great project. I built an indexer for my mini lathe completly (almost) with 3D printed parts. It works great and I have made three clocks with it (It is used to make the clock wheels (gears)). It is also driven with an arduino.
Thats an interesting design. Are the stl files available? I doubt my printer would be able to print that worm accurately enough but I might give it a try just because.
Thanks John
All motors can over heat. They need cooled and not under sized.
The programming of must include a a slow down at end to prevent over run.
The encoder will hole the exactl spot it does use electrical impulses just a mirror and set of two electric eyes.
The encoders take more programming than just simple using simple pulse.
On printer if lose one or two pulses you not see the error but gear it will make a difference.
Now try calculate the the pulses out for other errors.
The encoder off shelf I can find 5,000 Resolution. The stepper motor off the shelf I found was 1.8 degrees or Resolution of 200.
If great precision use compound indexing.
Dave, I hope you are talking about a servo motor. Yes, I suppose in theory a servo motor could be built using a plain old DC motor and a rotary encoder, but there would need to be some smarts somewhere in there!
Yes, In fact that is all many older servo motors are. The "Smarts" are in the servo Amplifier/Driver although newer servo motors have them built in as part of the motor
Skyline, I understand your point. Earlier in the conversation, it sounded like the suggestion was just to put a DC motor on instead of a stepper, as though one could just slap any old DC motor in place. This is where I hope the DC motor in question is actually a servo motor! But let me be the first to say, I may have misunderstood the intent of that earlier post.
Hello,
I had a look at all 21 pages and I found a lot of different programs.
I would like to build a controller with 4*4 pad and the 4 row LCD display.
I am little bit confused, where to find the latest version of Bruces program together with the wiring plan.
best regards
Edgar
I agree completely, The "motor" in question would need to be either one of the newer "self correcting" steppers with an internal position sensor and feedback loop to correct for missed steps or a true servo motor with a built in driver that could accept the same control signals (Step/Direction I assume). Both are pretty expensive components due to their complexity.
The cheaper and most often adopted solution (even in some quite large and expensive machines) is good old fashioned open loop steppers provided they can develop sufficient torque to overcome the likely resistance.
I have found the steppers on my machines are able to produce torques quite out of proportion to their tiny size and modest cost and rarely if ever "lose steps"
(and they are getting both smaller and more powerful all the time)
In a fault condition where for example an axis inadvertently hits a solid object that it shouldn't, open loop steppers actually have a slight advantage, they will lose steps until the controller "thinks" they are at their final position and then stop.
In the case of a servo, due to the feedback the controller "Knows" that it is not in it's final position and may continue to drive the motor in an attempt to get there.
This is a generalization of course and not always true. In reality overload protection should protect both the motor and to a lesser extent the machine. (whatever it may be).
So the choice is up to the individual both open and closed loop will work but for this particular application, I personally would stick with plain stepper motors.
Best Regards Mark
Are the stepper drives better now, I had a Summit-Dana Bandit control on a Bridgeport clone and the control did know when it hit something solid, it blew the power transistors on the axis drive?
