digiex-chris
- Dec 6, 2010
- 263
- 58
I'm finishing up my two stroke reconstruction, seems to run great! I'll make another thread with details. My question was, I messed up the wrist pin hole in the piston a little. I drilled with a numbered drill bit the same size as my wrist pin, forgetting that I needed to go undersize and ream. So of course, like all twist drills, I got a slightly oversize hole. The wrist pin is slightly looser than the original piston. The engine sounds a touch noiser than the original piston and sleeve, though I'm not sure if that's because of the wrist pin slap or because of the change in materials.
How much damage am I going to do by leaving it? I'd estimate I'm only oversize by 0.002 or so. Doesn't seem to affect running at all. It's a cast iron piston if that makes any difference. The interior of the piston is aluminum, for weight reasons, so the wrist pin is supported by both CI and aluminum.
