- Jun 24, 2010
- 2,425
- 959
I'm working on the wrist pins for my 5-cyl radial radial (24mm bore x 22mm stroke). The plans call for 5mm diameter 'hardened' steel & solid cross section through the length. No provisions were made for end pads which has me a bit concerned. The liner is cast iron & the link rods are 7075 aluminum, no bronze bushings but does have the classic angled oil weep holes feeding the wrist pin.
I had access to an older gen OS-FS-61, about 9% larger displacement. It has a 6mm diameter wrist pin, nylon end pads & a 3.5mm hole through the entire length. The end pads have a tiny weep hole.
- any ideas as to why the holes in the pads? Its not like lubrication on one side should be any different than the other? I thought maybe to drift a screw in there to remove but they popped out pretty easy.
- if my wrist pin is running in the aluminum link rod, does it make sense to harden? I've made some testers out of O1 so I'm covered, although I suspect the post-hardened dimensions will vary a bit which is a PITA trying to keep a snug fit on the piston & proper sliding fit on the link rod.
- I'm considering just partial drilling the ends of my wristpin with 0.118" dia hole x 0.100" deep & then permanent Loctite a brass end pad which has a matching 0.118" boss for the hole. See anything wrong with this approach?
Pic of my piston work-in progress alongside an OS-56-FS which is identical displacement. It has 5.5mm diameter wristpin, but I'm not sure if its drilled through or not.
