Nerdz
- Nov 19, 2013
- 115
- 19
Ive nearly completed my first wobbler, and its got me thinking as to how to improve it. Ive come up with a list and want some thoughts on it.
1) Slim Down Cylinder (Trim a bit from the sides not being used)
2) Slim Down the Piston (ie, make it hallow but fitting into the cylinder.)
3) Slim Down the Flywheel. Less weight in the center, more on the outside.
4) Polish All Contacting Surfaces
5) Bearings on axle load surfaces.
7) Exhaust Cooling and Refeeding
#7 Sounds Odd but what if we feed the exhaust into a cooler of some kind? I know this probably wont increase power but it will increase the efficiency.
Im no mechanical engineer, but Im thinking the first 3 would enable a simple wobbler to reach higher RPM's and possibly more power.
Also, what happens as we increase the Bore and Stroke of a Steam engine? Im almost tempted to scale up the wobbler to have a 1'' cylinder (actually how do you scale up engines?)
