- Dec 5, 2009
- 510
- 47
This is a work in progress thread for hobby machining, its not an engine, so I am posting it here on the breakroom forum.
I am in the process of doing a electronics project blog for a electronics forum I belong too, and I have a completed circuit built on my protoboard, and just now started to fabricate my printed circuit boards, for a permanent build, and so, I got out my old 1990's dremel drill press this evening, and found out that with todays modern dremel motor, that I had to get as a replacement for my 1980's model, doesnt fit the old drill press saddle, it is completely unusable for todays dremels.
I don't care to purchase another drill press for my circuit boards work, so I decided it was time to upgrade this old version, by machining a whole new saddle for it, out of aluminum bar stock, using whatever scrap I can find in my bins, and try to improve of the quality of this old drill press, the original used all plastic saddle, and that made for a nonrigid setup, I'm hoping that by fabricating this all out of metal, will improve the accuracy and stability of the unit overall.
Included in this video blog, I will need to machine the larger Vee clamping part as well as fabricate a clamping setup for the spindle nose of the new dremel design, as well as some dovetailing to fit the dovetail slide on the drill press column, then learn how to fabricate a cutter, and cut a miniature gear rack to match the original pinion gear on the drill press, so it wil be an enjoyable fabrication time, doing some measuring and layouts, as well as some fixtureing and setups, as I looked through my scrap bins, I am limited in size of material, so I will have to either machine the saddle in one piece as the original plastic, using some large round bar stock, or do a build up to get the thickness needed using the small rectangulars I have, thats all coming up.
As you can see in my videos, my electronics lab, and model machine shop, are in the same room, which was my bedroom located in our basement, where I moved into another room, to give way to converting this room into my machine shop / electronics lab, because of this it makes it very nice to work in here during the cold winter months.
Even though this is a electronics work in progress video blog, I am sharing this part with my fellow machinig hobbyists as well, as it pertains all to machining at this time.
enjoy.
here are the first set of WIP videos:
http://youtu.be/ChoiJN9QEGY
Introduction
http://youtu.be/4RZrNpOLRjI
Hobby machining series:
This is part 1
In this video, I start tearing down my old dremel drill press, and looking at design procedures for fabricating a new saddle for it, with some preliminary measurements.
enjoy.
http://youtu.be/l2ulxf4Mzsk
This is part 2
In this video, I do all the major layouts, then start machining to those layout lines, to establish the projection above the surface of the workpiece, for machining the dovetail slides.
enjoy.
http://youtu.be/DXsn7akga40
This is part 3
n this video, I machine the dovetails feature for a sliding fit to mate with the drill press quill, then a demonstration of the smooth fitting after it was lapped.
enjoy.
In the next set of videos, I will need to take my time as it requires more precision machining, I'll be machining the slot ontop of the dovetail to slide in and fasten the gear rack blank, as well as making a gear cutter, and cutting the rack, then working on the clamping mechanisms to be adjustable so as to give precision mounting for acurately drilled holes.
All that coming up.
enjoy.
Introduction
This is part 1
enjoy.
This is part 2
enjoy.
This is part 3
enjoy.
All that coming up.
