Hi Guys,
Does anybody have any info on this engine? When I bought the kit from Hemingway they said the plans are correct. I found the Yahoo site with the V8 group. The errors I'm finding are this....Here they are talking about the distance from the center of the cyl to the lifter holes in the block (copied from yahoo)
"One issue that no one has mentioned before is that there is an error on the drawing of the crankcase top part. The distance from  the centre of the cylinders to the centre of the cam followers should be 0.39775” not 0.400”.  If you build to the 0.400” dimension then the followers will be 0.00225” out of alignment with the camshaft. (Assuming crank and cam gear centres are 0.5625”.  If you draw it up on the CAD this will be confirmed."
Can anybody tell me how to work to 5 decimal places? ???
I really would appreciate it if somebody out there knows something seriously wrong with this engine. Please let me know. Otherwise the build will begin in 2 weeks
Tony
Tony
