Sshire
- Jun 29, 2011
- 935
- 267
I just ordered a geared variable speed motor to slow down my lathe carriage feed for finishing. I'm mounting it at the tailstock end with pulleys and v-belt to drive the feed screw.
I have this description:
"Rated voltage of this gear motor is 13.5 VDC and maximum speed is 50 RPM. Rated output load is 60 watts and output torque at 50 RPM is 11.5 N-m (8.5 ft-lb). Mounting is based on M6 screw mounting. The 12V DC PWM controller features a 4 ft(1.2m) long connection to its potentiometer. The potentiometer has a on/off switch built-in with a knob. An overload protection is set at 6 amps of current so the controller will shut down when such a current occurs. "
What kind of power supply should I be looking for?
Best
Stan
Best
Stan
