Does anyone recognize the screw / oiler / whatever that's on the eccentric on this Robertson Semi-Rotary Steam Engine? It's to the left of "H" on the eccentric. I think it may be there to allow you to reverse the direction of the engine. Perhaps there are two indentions on the crankshaft at 90 degree offsets? I don't think it's an oiler - it's in the wrong place.
Note that the eccentric linkage can be disconnected from the rocker arm "I" near "B" by using the handles. The original description says "The eccentric rod is hooked to the rocker arm I, the latter being provided with a handle, whereby to operate the valve by hand when starting the engine."
Maybe you disconnect the rocker arm, rotate the eccentric on the shaft, then operate the steam valve by hand to get the engine realigned?
Any ideas?
-10k
Any ideas?
-10k
