Due to the huge number of protest (Don), all entries will be returned.
Left handed was the clue. Maybe I should give it to my wife, she has all kinds of special tools to help with her affliction, left handed scissors, left handed potato peelers, etc.
Bogs, there is a reason that I did not carry the slot right across. When the bit makes contact with the workpiece, there is a moment of force that attempts to drive the bit into the slot. Grub screws may hold it but these are small screws. During the cutting of a 60 tooth gear, there may be upwards of 50,000 impacts on the bit. You almost have to expect some movement and any movement lessens the grip of the screw, leading to further problems. I want the cutter to butt against the end of the cut for improved rigidity and transfer of cutting forces.
To fix this one, I will take the slot right across and then drill and set a post in the slot to provide the buttress. There is enough meat in this head to do that. May not be in a smaller tool. It should work out.
Jerry
