Westbury Wallaby Likeness
D and D
Active Member
Nowra NSW Australia
A twin based loosely on the Westbury Wallaby nearing completion.
    26.1 KB
    42.8 KB
    54.8 KB
    44.6 KB
    48.9 KB
Finished
Engine is a 36cc parallel (360 Degree) twin based loosely on the Wallaby design by Edger Westbury.
Capacity: 2.2 Cubic Inch (36 cc)
Bore: 1.08”
Stroke 1.22”
Compression ratio 6 to 1
The engine was an experiment, I wanted to build something with the following:
Air Cooling
More than one cylinder
Closed oil system (Sump)
Pressure feed to the Big End Bearings
A High-Tension Distributor
Eccentric valve adjusters
Ground hardened camshaft with flat tappets.
  • Finished (1).mp4
    48.1 MB
