Can anyone help me source End Mills with a 3 - 3.2mm shaft in the UK?
I have one of they cheap 3020 cnc router/mills, and was only supplied with a single endmill. Although it has done me well for making various aluminium stands and bases from wood laminate, alas it has gone dull
Tried using the dremel end mill to finish off a wood combination lock that I was working on, that was a disaster, only got halfway around a base in wood at 25mm/min before it ended up in 3 parts, so that got returned to the supplier.
Its a good thing we have the 'fit for use' laws here, i told the guy behind the counter what i wanted to do with the tool and he said it would work - hence no problem returning the broken one.
