Hi Guys,
Whilst I fully agree that the model 3 cylinder engine is truly a remarkable example of miniature engineering at it's best, for which the builder can only be highly congratulated, I am,however, at a loss as to why, the science museum have made such a grave mistake in calling it 'A TRIPLE EXPANSION ENGINE'
IT IS NOT..... it is a 3 cylinder in line 'SIMPLE EXPANSION' marine engine.
Take a close look at the intake manifold...it is directly connected to all three cylinders.... this would not be the case for a true Triple Expansion Engine.
In a Triple, the first (HIGH PRESSURE) cylinder would be the only one directly connected to the steam source (in this case air)...the exhaust from this cylinder would then pass directly (often internally) to the valve chest of the second (INTERMEDIATE PRESSURE) cylinder, which in turn would exhaust directly into the final (LOW PRESSURE) cylinder and from there to the exhaust condenser.
A further clue is that each successive cylinder would be much larger than the preceding one...on this model all cylinders are the same dia.
The final clue comes from the statement 'this engine used to run on only the small puff of air obtained from a small rubber bulb'...firstly, such a low pressure air source could not possibly work a true triple expansion engine (even a modern high pressure compressor can have trouble doing this, it is most often just not possible to run multiple expansion engines on air)....on the other hand, such a small air supply could be more than adequate for a 'SIMPLE EXPANSION' engine.
so...sorry MR SCIENCE MUSEUM.... whilst I applaud your very fine efforts at restoring such a remarkable piece of engineering, I cannot say the same for your description of same.
Hope this does not ruin your enjoyment of viewing the video's etc guys....but I felt it only right to highlight the mistake being made.
Best regards .
SandyC
