Jim,
it sounds like you're getting close. At this point you can be fairly sure that both your valve and ignition timing are set close enough that the engine should run.
The most common problem, in my opinion, that beginners make with atmospheric intake valves is that the spring tension on the intake valve is too high. It is quite critical. When the tension is too high the intake valve does not open soon enough and the cylinder does not get a full charge of fuel air mixture. When this happens the power stroke is too weak to get the engine to run continuously.
I looked at the Webster drawings again and did a rough calculation of where the spring should be set. With the intake valve held in closed position and the spring retaining pin removed the top of the valve keeper should be about the top of the hole for the spring retaining pin in the valve stem or no more than 0.010 inch above it. With it set correctly you should be able to set the piston at top dead center where the exhaust valve is just closing and rotate the flywheel by hand fairly rapidly and if you're in a quiet environment hear the intake valve opening on the intake stroke. Since I'm an old man I can say this, but it should sound like an old man passing gas as the intake valve will vibrate. The valve will only move a few thousandths of an inch so only rarely will you be able to see it move.
If this doesn't cure the problem, then you probably have some compression leakage in either the piston cylinder fit or the valve seats. It's fairly easy to determine which and I will be glad to walk you through it if necessary.
Gail in NM
