- Jan 17, 2009
- 1,081
- 278
Many folks have successfully built and run engines using Viton O-rings as piston rings.
My question is:
How much deformation (squeeze) between the bore and the bottom of the piston groove should be applied to have a good seal with the minimum friction?
With reference to
http://www.applerubber.com/oring-gland-calculator/
The compression parameter is given to be between 10% and 30%
What have you found a good compression figure for you engine?
My question is:
With reference to
