(video) my design 4 cylinder OHV engine
gbritnell
Gentlemen, I finally got around to running my 4 cylinder so I set up the camera and took a short video clip. I didn't put it in my original thread because I figured most everyone had been there and might not go again.
gbritnell
[ame]http://www.youtube.com/watch?v=yYKUlcy-g1w[/ame]
What a beauty! love the size and sound. Great job, Thanks for the video.
Very nice gbritnell. Nice sounding too.
Question for you. How long could that engine run at say 75% throttle. I'd like to build something like that someday and install it in a swamp boat or airboat.
Bernd
Thank you gentlemen for the comments. Bernd, If I was going to use something like this for an airboat I would change the cylinder design to aircooled. Why go to all the trouble of a radiator and plumbing when using the airflow would simplify everything. As far as how long it would run at 75% throttle, the only answer I could give would be until parts start to wear out. I have about 3 hours running time on this engine. That doesn't sound like much but when you start it and run it for 4 or 5, 1 minute spurts at model engine shows it takes quite awhile to get 3 hours out of it. I have torn it down once in that time to check wear and the only thing that needed adjustment were the big ends of the connecting rods. I made them out of bronze so I just remove the caps and take a small amount off of them till I get my clearance back, reassemble and fire it up.
gbritnell
Well yes, an air cooled engine would make more sense, but I like the thought of having a liquid cooled engine. You wouldn't need a radiator since you could use the water the boat sits in. You would just need a pump.
My main concern was how hot an engine like that would get if run for 20 to 30 minutes continuously at 3/4 throttle or even full throttle. Although I don't think one would do that since your going to throttle up and down as you drive around.
Thanks. It was just some random thoughts I had and since you have built one I thought I'd ask for some first hand experience.
Bernd
Bernd,
In the early days of radio control model boats, multi and single cylinder four stroke petrol engines were the most used type (glo-plugs didn't come along until later).
Almost any of the old plans for that type of engine would produce a reliable and long lasting power plant. Getting the castings nowadays is the problem, but nothing is insurmountable, and remember, they were made with machinery and materials that to us would be classed as rather basic.
That's not a motor that is a work of art and something that a lot of people would only build in there dreams, I am so impressed with that, that would a life dream to build one like that, you are to good, thanks for the show of you fine work, Lathe Nut
Thanks once again everyone. I got started in model engine making many years ago. It started with some Stuart 10v's, water pumps and assorted other miniatures. After a number of years of steam engines I got into gas, mainly some of Paul Breisch's hit and miss engines. Around that time the first NAMES show was taking place in Ann Arbor, Michigan. I didn't get to the first one but made it to the second one and this introduced me to what others were doing with "scratch" building. I designed this engine as a simple inline overhead valve engine. As with any engine, scratch or from castings, there's the machining but more than that is all the tinkering and modifying to get the darn thing to perform well and this one has had it's share of both. At one time as the rings were seating in and the compression came up I had to make a head spacer to get the compression down a bit and now I find that I might have to do it again. The reason I say that is because I would like it to idle a little bit slower but with the high compression, and small flywheel, what you see in the video is about as slow as it will go. It is mean sounding though!
gbritnell
VERY nice! Sounds like a little Offy. Luv' that "cammy" idle. Brings back memories of my old 1275 cc Spridget with aluminum flywheel, 11:1 pistons and Huffaker cam. ;D
That little beauty would be awesome in an r/c scale model 60's era midget.
Have you run it in the dark to look at the exhaust colors?
:bow: :bow: :bow:
Wow! I love the sound of that little engine. Very very nice. Job well done sir!
Eric
That is an awesome looking and running little four banger! Great sound, too!
the engineer, Welcome to the forum. Glad you joined!
Well I think thats brilliant not only on the quality of engineering but also for your design. Something you must be very proud off. Whats next? :bow:
Hey Gbritnell
Really nice engine!
Do you also have some pictures of the individual components?
Florian
:D wow you made that, every little part even the carb?
is it even water cooled?
I designed and made all the parts for this engine. It is water cooled, at least the block is. The block is aluminum with the jacket area machined out and then a head plate is pressed onto the iron liners. It has a small water pump on the front to circulate the water.
gbritnell
