Hi guys
So i live in South Africa, and im interested in building a V8, distant future project ^^.
Now to do this i am busy designing and researching all the different bits and pieces, and one of the parts im on now is the distributor and ignition system. From what iv been looking around and searching on this sight, the biggest problem that many have is that they cant get the distributer and coils to keep up with the spark at higher revs.
Since im planing to stick the motor i make in a R/C car i need it to run in the higher rpm smoothly and effectively.
The idea i have is instead of using one coil and distributor with 8 separate contacts to power each spark plug, would it be possible to split it between 2 distributors and have 2 separate coils. in turn having an ignition system for each side of the engine, essentially driving 4 spark plugs per ignition. i understand that each ignition would have to be timed in completely separate to the other.
Another question i have is, how much does these ignitions draw? would i be able to power them off 3 cell 2200mah lipo batteries?
Sorry if i dont come across very clear or precise, but im still new to all this and trying to learn how it all works ^^
Any questions are welcomed and any advice and criticism is encouraged.
Thanks all
Cameron
Thanks all
Cameron
