V4 Steam engine Model
http://player.youku.com/player.php/sid/XNTkwNzAzNjcy/v.swf
Overall dimensions: (mm)
Bore : 14mm
Stroke : 16mm
Each cylinder Capacity: 3ml
Planetary Gear ratio: 4:1
Flywheel diameter : 37mm
Output shaft : 5.5mm
Other Output shaft :4.5mm
O.A. Length : 150mm
O.A. Width : 110Mmm
O.A. Height : 90mm
Net weight : 130G
Bore : 14mm
Stroke : 16mm
O.A. Length : 150mm
O.A. Width : 110Mmm
O.A. Height : 90mm
Net weight : 130G
