V4 Wobbler - double acting - magnetically held (no springs)
2D ACAD *.dwg & *.dxf plus *.doc build notes
View attachment V4WOBBLE.zip
Do you have a movie of this running?V4 Wobbler - double acting - magnetically held (no springs)
Richard, I added it to my response to your thread - you were too quick we've crossed.
Regards, Ken
Ken,The V4 is a little more challenging because of the complex of Ø2.0 & Ø2.5 deep drilled holes - requires a long series drill and careful planning and care at the intersects - if you break a drill off down there you are going to be in trouble - the build notes cover this.
Making 4 sets of cylinder parts is not that much work as you go into "production" mode.
Drill the deepest holes first and all the "breakthrough" holes on the shorter legs. Use a Vernier stop at the breakthrough to stop "snatching".
The V4 drawings have a version (above) without the "afterthought" throttle parked on top - designed into the body - in the middle of the "V"
Regards, Ken
