sourdoughsmitty said:
I purchased some r8 collets for holding the end mills in my mini mill , These were from grizzly evn when the collet is sucked down tight as the existing draw bar will let me i can still move them in the collet ??? When I get to work tonight I will look and see what we have for shim stock as well as making a longer draw bar these are the only things I can think of to do ,I have no way of checking the tapper accuracy up in the spindle , my end mill measures dead on at .500 while the hole in the collet measures aprox .485 when the collet is relaxed have not had a chance to measure it wen it is drawn up any ideas here or perhaps i should have actually bought mill holders in the first place ;D thanx smitty
Smitty, The collets are probably NFG. I am positive that, so long as massive time has not accumulated since you received them, Grizzly will make good on them. R8 collets may be a couple of thou "off" in the "relaxed" condition, but not a whole lot more than a couple of thou off (call it .497/.503 for a nominal 1/2 inch collet). If the rest of your collet set is good in that way (stop and measure them
now!), the people at Grizzly are likely to just send you a new collet based on your say-so. If the most of or the entire set is bad, they will probably want them back to shove down the throat of their supplier.
If you "tap" the collet all the way "up" into your spindle, the drawbar should sit loose (i.e. no threads engaged) with its shoulder about 1/2 inch above the bearing surface on the end of your spindle. If it is sitting (say) 3/8 inch or less, a new drawbar is in order. If it is much higher (say more than 3/4 inch), then you should make a special washer to move it down into the 1/2 to 3/4 range (there is almost an inch of thread in a standard R8 collet). I have the specification drawing for an R8 collet if anyone is interested.
It's less about
who you buy your collets from than
who made them. Royal and Lydex collets are rarely more than .0005 off dimension with runout in the .0002 range. I see many of the import collets having a runout in the .0015/.0010 range. I have even seen some of the early Chinese collets that were so bad that you could
see the runout with your naked eye (though, I admit, that was years ago and I have
not seen such a situation since)! I have become quite a
tool snob over the years.
