If I want to true up a thin piece of stock (say 6" x 1" x 0.25") along the long edge, what size end mill should I be using.
Would I use a 0.25" and use the full diameter of the cutter but with a small DOC or should I use a wider cutter. If a wider cutter do I offset the cutter so that it uses the 'outside edge' of the bottom face or should it be centralised over the stock ?
Does any of that make sense ???
Jim
Jim
