- Dec 28, 2008
- 1,731
- 9
Good news, Engine #4 is in running order! I had a bit of a problem with Hall sensor failure yesterday. I lost four of them in a row! I called Roy Sholl at S/S Machine & Engineering to see if he could help. Roy was very helpful and indicated that this can happen on occasion, and the solution is to simply isolate the Hall sensor and its prongs with shrink tubing, and to isolate the magnet from the metal carrier disc with a plastic bushing, or a .030" plastic spacer glued over the face of the Hall sensor. This will prevent any charge from passing from the magnet to the grounded hall sensor. As a first experiment I covered the three prong on the hall sensor with shrink tubing before gluing it in the sensor carrier, and that is working so far. If I have any more failures I will try adding a full 1" diameter .030" thick Delrin spacer between the sensor carrier and the magnet carrier disc, or I might drill out the magnet carrier for a Delrin isolation bushing to house the 1/8" magnet. Roy indicated that a damaging discharge has a tendency to pass more readily through the magnet than its carrier. A non-conductive magnet carrier would also work.
This engine displays a sensitive needle valve adjustment just like the #3 Horizontal F-Head. But It starts easy enough and runs strong, with excellent compression after a 20 minute break in run. All's well that ends well!
[ame]http://www.youtube.com/watch?v=bsUiDGxXEVk[/ame]
-MB
-MB
