- Dec 28, 2008
- 1,731
- 9
I got the #3 engine to start and run without to much fuss, and then shortly after wards a few problems developed. After about ten minutes of running the engine stalled due to a severe drop in compression. It turned out that the piston rings rotated, and their splits ended up in line with each other. The second problem was the intake valve leaking, and puffs of white smoke could be seen coming from the carburetor. I tried another intake valve and it didn't solve the problem. Then I took a very light cut on the valve seat with the valve seat cutter and that didn't help. Finally I gave the first valve a light lapping with some metal polish and that worked.
In the video you can see that the engine runs inconsistently, and the needle valve needs to be adjusted periodically to keep it running. It seems that the needle valve on this engine is more sensitive than the first two engines. Since its not in 'good' running order I'll have to look deeper into the cause of the erratic behavior this engine displays. But for now I'll set it aside and move onto getting build #4 assembled and running.
[ame]http://www.youtube.com/watch?v=Ol5Uuf6xrH0[/ame]
-MB
-MB
