• If you have bought, sold or gained information from our Classifieds, please donate to HomeModelEngineMachinist and give back.
    You can become a Supporting Member which comes with a decal or just click here to donate.
Uni-flow steam engine castings
DougLanum
Active Member
I have a set of Reico Uni-Flow steam engine castings to sell.
These were made in Grafton, Ohio in the 1970's and 1980's. They are no longer available.
1 1/4" bore, 2 1/2" stroke.
7 1/2" dia. flywheel.
Overall dimensions 18 1/2 x 11"
Aluminum cast base.
Cast Iron and brass castings.
Cylinder is fitted with two piston type valves, one to control the entrance of live steam, the other to relieve compression on the return stroke.
Feed water pump casting included.
Weighs about 40 pounds.
Asking $200.00
Doug
