Type B vs. Type KM ER nut
Whichever type/manufacturer you go for, it would be well worth getting the ball bearing nut version.
ER Collet Nuts with Ball Bearing - Type B in Bogs' link above shows them. Also available from other locations.
The Emerald Isle
As with most things Pete, ER collet holders are made with different threads, even in the same size. I think it is to do with the overall OD, smaller ones can get in smaller spaces.
I use ER16, but there are two sizes of threads and so nuts, I use the smaller diameter one, so you must make sure you order the right one for the holder thread even though they hold the same sized collet.
Thanks for the info John. I've been looking at acquiring an ER chuck for
my little mill that uses MT2 collets. I have seen all sorts of nomenclature
for what appears to be the same items. Based upon what you've told me
I should just pay attention to the nut threads as the main compatibility
issue. I've seen some chucks with the smaller nuts and really like the idea
as visibility for the smaller cutters will be improved. So it would seem that
I could probably obtain a smaller nut to fit if the unit doesn't come with a
small one.
Thanks!
Pete
Pete look for mini nut , these are smaller in diameter than the standard nut , I used one for an ER20 chuck which I made to fit my Pultra
instrument lathe.
It works very well and fits both headstock and tailstock , as it is tightened with a spanner it grips better than the original collets especially for tapping under power when I often found the tap would slip .
Oh............remember to order a spanner to fit whatever size you decide on !
Dan.
I'd love to buy from Arc Euro Trade, but unfortunately they won't process my American credit cards.
Their 'terms' page says they take US MasterCard and Visa. I have used a Visa Check Card with them. Bought the ER32 square and hex collet blocks, C spanner, as well as a bearing collet nut from them. Great quality and service.
Chuck
Looking at the two photos on Amazon the most apparent difference is the slots for the collet wrench. Plus the KM version is balanced for higher RPMs according to the web page.
Chuck
I know, but when I try to actually pay it rejects me.
Well, I've learned something today. I never realised that there were different thread possibilities for the same size ER chucks. When I've ordered spare/replacement nuts for my ER32 chucks, they have always come with the same thread - fortunately. Maybe British suppliers (from whom I have purchased) stick to one standard which may be different from suppliers in other parts of the world.
Thanks for alerting me/all of us, John.
The Emerald Isle
I've learned a lot on this subject from you folks and I want to thank you.
Between your comments and looking more closely at the specs in the
catalogs I think I know what to watch for and ask for.
Thank you all!!
Pete
Has anyone ever heard of an ER nut not having the offset flange?
You mean where you fit the collet into?
When new, some of these are very tight indeed to get the collet sited, giving the impression that they are not the right size, but after a few ins and outs they do get better as the sharp edges in the nut get round off slightly.
I don't see how a collet can be mounted without that cutout, or offset flange, as you call it.
Yes.
I'm not asking to try and find one without it. I'm asking because I bought a nice ball bearing ER25 nut which didn't have it, and I'm trying to find out if it's just defective, or if I accidentally bought some special style of nut which doesn't have it.
Do the collets fit OK into the holder?
Is the runout acceptable when tightened up?
If the answer to both is yes, then just use it.
I am not saying that such beasts don't exist, but are you really sure that there is no relief anywhere around the circumference of the ball race, then something must have been done to allow the collet to fit into position, and if it is just a matter of having a larger hole, allowing the spring of the collet to be compressed to get it through the hole, then I personally see no problem as all the nut does is push on the nose of the collet to close it, so the hole that the collet sits in plays no part in the correct operation of the collet.
The only problem that I would forsee is the collet is not locked into the nut as per normal and so the collet could fall out when it is fully unscrewed from the holder.
Clear as mud he says.
The problem is that offset flange provides the self-extraction of the collet. When you loosen the nut it pulls down on the collet and pulls it out of the chuck. Without it you can take the nut off and the collet and tool will remain stuck in the chuck.
What type of collet chuck do you have? is it a flange mount? Taper mount?
If a flange mount it has a through hole. Find a dowell or wood broom handle that will fit through the headstock and the chuck and use that to tap the collet out.
Chuck
