B
Bogstandard
Guest
I started off this little project with the cylinders mounted side by side, but it got a bit hairy when the flames started to shoot about and interfere with the opposite flame, so I decided to go with a boxer configuration. So I salvaged what I could from the original, made new baseplate, burners and a tank. This is to show how I got on with that exercise.
And to really show how it got on, try this next bit
<embed src="http://www.youtube.com/v/IyrWRBoC-2c" type="application/x-shockwave-flash" width="425" height="350"> </embed>
Except for a bit more polishing and reshaping the project has been a success.
Just a few words to people who are contemplating making one of these engines. On the plans it shows the burner at a certain height, I couldn't get it to work with this dimension, if you need to set them up the same as mine, just ask. The other problem that I found with the instructions was that Jan said you can use a bit of thin oil on the engine once it had warmed up, only use a minute amount on the little end pin and maybe a bit on the cylinder where the pin runs right thru it, otherwise the engine will totally sieze up with a gummy deposit.
