pkastagehand
- May 1, 2011
- 173
- 32
I didn't know if this should go in questions and answers or here in tools. I'll try here...
I bought one of those Horror Freight pipe benders; you know the one with 3 wheel dies and a big hand wheel to turn it. The dies are all for round tubing. I want to bend 1 inch square tubing. I have done this before with a homemade unit built similarly to the HF unit but no hand wheel. Just had to push/pull the stock through it. Also, the wheels were just flat cast iron wheels and I used posts with bushings along the side to guide the tube (relatively) straight.
I was thinking that similar to the round tube dies, if I made wheels with a square walled profile they would guide the tube for me. The wheels started with 4 inch CRS slugs. I have them 1/2 inch deep (on the radius, leaving 3 inch diam.). Is that enough? Too much? I figured half the tube gets me to the neutral axis where no compression or elongation should be happening much.
The bottom rollers are on the outside half of the curve where the tube is in elongation so side clearance may not be much of an issue.
The top roller is on the inside of the curve and is the side that is in compression in both in terms of length as well as maybe some flattening. I started with only about .030 inch side clearance. After starting to curve a test piece I'm already starting to wedge in the top wheel because of the deformation. Any ideas how wide I'm going to have to go and can it only be the top roller that gets widened? I suppose it depends on factors like tubing wall and radius of bend. Other factors?
Paul
Paul
