I am interested in trembler coils, similar to that used in Model T fords. In a conventional points style ignition, you get one spark at the plug when the points open. With a trembler coil system, you get a series of sparks whenever the points are closed. There are a ton of "How to" articles on building your own trembler coil on Youtube, and it seems that I already have most of the components (a 12 volt coil and a condenser.) It seems that all I need to buy is a special relay, which is commercially available. Does anyone have more information pro or con about these trembler coil systems?---Brian
