Topsey Turvey by El Gringo
el gringo
north west ca adjacent to lake pacifica
Design by Phillip Duclos
[ame]https://www.youtube.com/watch?v=SUbn_eUr-9M[/ame]
As usual perfectly made engine.
Does termosifon water cooling work properly ?
I want to use it for my new engine but I am not sure if this type of cooling system really works on small engines.
Thank you
A friend build one of these, and I started it one day. It slung a nice line of oil down a brand new shirt from my shoulder to my belt. Ruined an almost new shirt. I have since not been fond of those engines.
But this is a nice bit of model making.
I had too much compression causing low speed and heating problems.
I installed a large cooling reservoir and lowered the compression and things got better. The radiator removes some of the heat.
If I went back to the original design the thermo-siphon would probably work ok.
I don't think this type of cooling is well suited to these small low compression, low RPM engines.
What type of engine are you thinking of building next?
thank you el gringo for your answer.
I have half finished engine // roughly 10 ccm // . This is my first
water cooled engine so I do not have any experiences with water
cooling
I will probably machine some kind of primitive radial water pump.
Kadora
