- Jan 4, 2011
- 1,417
- 384
I notice some folks saying that they will not buy anything but high end tooling and high end machines but for many of us the difference between enjoying the hobby and not being able to afford it. It may be nice to buy $20 taps instead of being careful with the $5 tap but can it be justified? For some things the expensive one is actually made by the same company as the cheaper model. For instance take a look at the 5C spin indexer. They can be found listed for anything from $29 to $89 and they sure look like they are identical and made by the same company. For some things like telescoping gauges I find it hard to believe that the $150 set is that much superior to the $29 set. We are using them on an occasional basis, not 8 hours per day 7 days a week.
For me I could probably afford to get the expensive one if I really thought that it was important but I would have a problem justifying that for something that is just a hobby. Back when I owned a fabricating shop I could justify paying $150 for a drill motor because it was being used for hours on end but now the $39 drill motor is used to drill two holes every other month and if I drilled 20 holes in a row it would overheat but I am not doing that. If I actually had to drill 20 holes I could drill 10 and go get a cup of coffee and come back to drill the other 10.
In many cases it is possible to compensate for less than perfect equipment. If something is .005 oversize it may be possible to make the mating piece .005 oversize. In reading the build descriptions by some of the old timers you find them putting a shim on the lathe chuck jaws to compensate for less than perfect equipment. If you look at some of Rudy K project logs you see him using machines which he salvaged from the scrap heap and rebuilding and making them work for his purpose.
We all make choices and set priorities and I realize that other make different choices and that is perfectly alright. YMMV
