Hi
Materials: similar to another model engines - piston: 6061, 7075, gang - cylinder (engine and pump): cast iron, steel - connecting rod: aluminum 6061, 7075, steel -.....
"tips for designing my own diesel engines"
I don't know, but I will say what I know from my experience and note: I am not a professional in engine design and other things, just an amateur.
As I asked you before: have you ever built an engine and I don't have an answer from you so it's hard to know your experience and knowledge, so I will say some basic things.
For me when designing an engine I have to base on what I can do, or at least based on my experience and judgment that I can do. With any engine I have done, the Cylinder is the first and most important part and then there are other parts that I can do to make sure the engine can run
For example: with a 2-stroke or 4-stroke engine - ignition, I can design it with a cylinder diameter I can do 2, 3, 4, ....12...14...mm but with the spark plug, how can I ensure its insulation with such a small area? With a cylinder that is too small, it is impossible at least for me,. so what about a larger cylinder like 14, 16 mm: it is ok but the spark plug seems quite big compared to the cylinder head....
What about diesel engines (injectors)? It's similar, but it also depends on the amount of fuel injected into the cylinder. And it is determined by the diameter of the fuel pump cylinder and the lunger stroke
That means I have to determine the diameter of the pump cylinder that I can make or rely on experience to know how small I can make it in mm and from the amount of fuel I will calculate the diameter of the engine cylinder, stroke, length of the cylinder, ....
The position of the gear, crankshaft, camshaft .......
A complete engine requires all the parts to be combined into a unified assembly
For example, the crankshaft you cannot use the parameters of a 4-stroke engine with a compression ratio of 6-1 for a diesel engine crankshaft with a compression ratio of 20-1 or use a 10 cc diesel engine crankshaft for a 50 or 100 cc diesel engine ...
It is difficult to give you a useful "tip"
Most useful: Start with what you can do
