I had some QCTP toolholder blocks I wanted to knock about 1/4 inch off. They are alloy steel, and hardened at least to some extent.
I tried with a regular HSS end mill (4 flute... first a 3/4 then a 3/8 if I recall.) but they both kind of melted. (They were cheap.)
So, it gives me an excuse to try something new, and they had (Still do I think) TiAln coated roughers on sale in the clearance section of Enco. A 3/8" one was around $15. So, I gave it a whirl.
http://www.use-enco.com/CGI/INSRIT?...PMKANO=274&PMKBNO=2335&PMPAGE=5&PARTPG=INLMPI
Turns out, the speeds and such were kind of out of reach on my Mini mill (According to G-Wizard) I was looking at about 1800 RPM with a 17 IPM feed rate. The RPM was achievable, but 17 IPM? LOL... lets see... 16 turns an inch x 17 IPM, 272 RPM, or about 4.5 cranks per second. LOL.... maybe when I was younger.
So, what the heck... I drop the RPM a little (1500-ish) and just crank the hell out of it. It cut like a DREAM.... 1/4" DOC, about the same in at full on crank-it speeds... no major freakout by the mill. Had the whole QCTP cut in less than a minute. Sweet! (It also "proofed" my column upgrades... BIG improvement.) No coolant used either, dry cut.
So far so good.... I was ready to mortgage my house to get a bigger collection of magic TiAln bits, or invest in a ore mine or whatever, LOL.
Drop the next QCTP in to be milled... right off the bat it's taking a lot more pressure to crank and not cutting nearly as well. By the end of the 3 inch or so straight run it's glowing red hot and just not cutting well at all. I checked the bit after the first run and it seemed fine. After that it looked like a melty ball nose end mill. Gummed up with metal BUE and rounded over.
Do you figure it was too fast, or not fast enough? Or is the Mini mill just not bad-arsed enough keep that kind of bit in it's comfort zone? Another thing I can note... the second QCTP was a different brand. Maybe the steel was gummier?
Anyway..... the first run was so awesome I want to be able to do that all the time... just not with a bit that self destructs, LOL. Any ideas what I was doing wrong?
