- Aug 8, 2009
- 929
- 12
Guess you have to be kind of old to remember that commercial, and live in the States. Anyhow...
I started an Upshur Hit and Miss build thread some time ago. It's lost in the archives now and I'm not going to revive it even though I'm still working on it. Instead, I'm going to post progress on three engines I'm building simultaneously. It's fun making a part for one, then making a part for the next, another part for the third and back to the first engine again. Keeps my mind from obsessing over a single build. While I'm waiting for parts or tooling for one engine, I can work on the other two.
As mentioned, the first engine is the Upshur build which I have referenced to in earlier posts. The second is Elmer's #4 Beam - it's small and cute. Third is Monsieur Bog's Paddleducks, lots of little parts to make for that one and it looks like fun. My wife liked it when she saw a picture so it's as much for her as for me.
Here is a pic of all three. As you can see, I've got the engine block for the Upshur nearly finished. The cylinder in the foreground is cast iron and is part of the Paddleducks build. The flywheel and base is Elmer's Beam.
I tried to be fancy with the finish on the cast iron block. I used a Dremel grinding wheel trying for that swirly effect. It took on a different character than what I was shooting for but it looks good enough.
Close up shot of the flywheel for Elmer's Beam. I had an experimental brass flywheel hanging around but it was too small for the engine. I turned a piece of aluminum to get the desired diameter. The brass adds weight and the aluminum adds size and together they look happy, so it came out well.
I don't think this will be a build thread per se, as I don't plan on documenting all the steps I take. I'll just post some progress pics from time to time. Thanks for looking guys.
-Trout
-Trout
