This is my flame eater, but the harder it is to run ( sometime run about 30 second) maybe bore of cylinder is small (14mm) It not enough power to run or valve is not good with fire.
yes .. flywheel made of aluminium, maybe..Are your flywheels Aluminium? if so they could be a bit light.
Hi Minh Thanh..
Read here (click at ---> "click here for English")
http://ridders.nu/Webpaginas/pagina_ervaringen_tips_happers/ervaringenhappers_frameset.htm
IIf it's running for 30 seconds at a time it can't be too far out from continuous running.
Or cylinder is not cold enough to create vakuum. If the cylinder is allready hot after 30 seconds, It will not run.
