There doesn't seem to be a section on general machining questions, so I'll ask here. I make a lot of parts from 1/8" thick aluminum plates. I've notice that the plates tend to bend when they are clamped down. I don't think I'm doing anything different than I used to, but it is more noticeable now. Especially when I have to space it above the table a bit to allow for cutting through in places. Here is a 4" x 3" x .125" plate clamped down at the ends.
I have 1/16" thick aluminum pieces at the ends, under the plate, where it is clamped, and one in the middle. The plate deflects up in the centre so the ends are about .010" lower than the centre. Not a huge amount, but when you are machining features .015" deep, it basically is no good. I could clamp it at the top and bottom too, but that seems excessive for such a small piece. I've resorted to pre-bending the plate up at the ends to try and minimize this, but that's not a very good solution.
Any thoughts on why this happens and what I should be doing different?
thank you,
Rick
thank you,
Rick
