In 2014 I purchased a Sieg milling machine, the SX2. It didn't take long to get tired of winding the X axis crank back and forth, motorising this was the first modification I did on the machine. I wasn't very cashed up at the time (I never am) so I utilized the motor from an old electric screwdriver and managed to cobble something together that worked OK for most of the time. The power in these little motors is quite astonishing and coupled with the planetary gear set it had little trouble in driving the table in either direction against a cutting load. Three problems with the system were; a) The motor would run on a bit after power was removed and this impinged on repeatability. I fixed this by connecting a relay across the motor terminals that shorted them out when the motor was powered off. The back EMF in the motor would bring about an instant stop. b) The motor speed is controlled by varying the applied voltage and the torque falls away dramatically at low speed, nothing I could do about that except to constantly adjust the speed. c) The setup needs some sort of clutch to disengage the motor from the X lead screw to allow the hand crank to be operated. Not that big a problem, I used a primitive form of dog clutch and this worked fine.
After two years I sold the little mill and invested in an Optimum BF20LV, similar to the Grizzly G0704. The X axis motor was simply transferred and has been working tirelessly ever since, however after making a motorised rotary table using a stepper motor I began to get the idea that this type of motor might be ideal to use the drive table. That's what this blog is all about, using a stepper on a manual mill. More to come, a couple of pics of the gallant little screwdriver motor, I will be quite sad to see it go.
Cheers, Peter.
Cheers, Peter.
