The "None Compression Engine". I need info.
kode1303
Hi there,
Sitting here in cold Scandinavia, I am thinking of future projects and found this forum so I joined up right away.
My status is newbie both here and in engine building, but I am fascinated by the 'None Comprssion Engine' and would eventually like to build one. I found one post here from back in '09, but it didn't say much.
So - my question is if any in here can give some hints, links, plans or any info on this engine type.
My thoughts of the engine is that it should be simple with standard spark plug (like for weed eaters) and easy-to-make valves etc. I'm thinking of a bore diameter of about 25mm or one inch. Fuel sould be normal petrol fed from a simple vapor 'bubble karb'. I like the thought of water cooling, so a soldered radiator with a pump would be nice to make too.
I'm a science teacher and is 'OK' with my hands. I have basic hand tools, a drill press and a small lathe that I haven't worked all that much with, so my lathe turning skills are probably basic too.
A link from YouTube just to show the kind of engine I'm thinking about:
An 'ugly' one:
[youtube=425,350]http://www.youtube.com/watch?v=t9lW2RHXFFg[/youtube]
A Nicer one:
[youtube=425,350]http://www.youtube.com/watch?v=ocA_JQ4sZSI[/youtube]
I'd be thrilled and happy to receive any help on this subject.
Thanks!
J. Rasmussen Denmark, Europe.
My YouTube links doesn't seem to work that well (what did I do wrong?), so here are the links again:
'Ugly'
[ame=http://www.youtube.com/watch?v=t9lW2RHXFFg]http://www.youtube.com/watch?v=t9lW2RHXFFg[/ame]
'Nice'
[ame=http://www.youtube.com/watch?v=ocA_JQ4sZSI]http://www.youtube.com/watch?v=ocA_JQ4sZSI[/ame]
Hi J;
Welcome from cold Canada.
Search for Sombart engine, this is the only non compression I have encountered. There is one at coolspring and I have seen one running model here in Can. I don't quite understand your comment about a vapor carb. I think if it has vacuum for a liquid fuel carb it will have compression.
Peter
Thanks for the replies and links!
Peter
Peter,
Yes there must be at least some vacuum to suck in the vapor/air mix from the carb. However, as the exhaust valve is open all the way when the piston goes up, compression does not happen. ;)
Anyway - this very simple and unusual functioning is why I'd like to make one!
Hi J. I'm a Newbie - signed up just today. The same two engines that you posted from Youtube have caught my interest also. So I've started research and found this forum. Everyone here seems so knowledgable and interested in helping, but I feel daunted and humbled by their level of expertise and wisdom. I have limited experience and only basic equipment but hope to increase my inventory of both and build a simple engine. I'm sure that we have come to the right place here. Please post as you go, and I too will grow. Good luck to you. Ralph
Hi Ralph,
I take it you are the same Flyingtractors1 that builds beautiful little brass solenoid engines that are displayed on youtube?
Chuck
Hi, Yes, and thanks. I have built about every solenoid engine configuration that I could imagine and enjoyed it immensley. A collection is posted on YouTube by flyingtractors1. Steam power has also intrigued me, and now I want to "graduate" to Internal Combustian Engines, but I don't really know where to start. They pose new challenges that may be beyond my present skill and equipment level. I need to knowledge up and find more tools. Advise me?
Hi Ralph and welcome to the forum.
If you are looking for a first IC engine, you could look at the Webster 4 stroke http://www.john-tom.com/html/SteamPlans2.html about half way down the page. There must have been at least 100 of these engines built around the world.
Another excellent site is Jan Ridders. http://heetgasmodelbouw.ridders.nu/ He has several IC engine types. To get the drawings, just send him an email telling him which design you would like and he will reply pretty promptly.
Both these sites will have sufficient engines of all types to keep you occupied for a long time.
The Emerald Isle
kode1303 said:
I made this drawing (PDF file on my DropBox) of the funktion of the non compression engine - as I understand it!
I hope I'm not way off :-\
http://dl.dropbox.com/u/6297142/NonCompressionEngine.pdf
Your drawing looks correct. Attached is another drawing, approximately to scale, showing the crankshaft positions where the valves open and close and the engine fires.
I wonder if, instead of a cam operated inlet valve, you could just use a weaker spring and let atmospheric pressure (vacuum) open it on the intake stroke. When the engine fired, the pressure would close the intake valve. I believe some other types of early engines used this method. Another thought, instead of spark ignition, maybe you could mount a glow plug in the side of the cylinder so the piston would uncover it at the appropriate firing position.
I also believe that a vapor carburetor would work just fine.
Chuck
The earliest internal combustion engines were non compression.
Here are links to the videos of Otto Langen early engines and a link to a description.
[ame]http://www.youtube.com/watch?v=85HkJCqjbrA[/ame]
[ame]http://www.youtube.com/watch?v=Zs56Cii3kdg[/ame]
http://sites.google.com/site/wgrenning/home
They were atmospheric engines in that the power stroke was when the hot gases cooled they created a partial vacuum in the cylinder and atmospheric pressure provided the power stroke.
A number of models of these engines have been built and at least one casting kit produced. They are great to watch run at model engineering shows.
Gail in NM
WOW! I jumped in on J's question ( please forgive me, J ) and have already received substantial response to my quandry ( one I share with J ). Thanks alot, guys. I am now busy studying the literature and have already learned much. Hope you also have, J.
Yes, Jan Ridders (Who is mentioned above), has used a spring loaded ball valve for intake in his engines. He only - as far as I have seen - use the vapor carb to feed his engines. He actually sparked (get it??) my interest because of that simple carb when I realised that I didn't have to build a 'real' one.
With only the exhaust valve to be controlled by a single 180 degr. cam the engine gets even simpler.
Thanks.
You're forgiven :D
I'm only glad that more are interested in the non compression engine. From what I can see, you are indeed quite skilled with a lathe etc., so maybe you can be a forerunner whose experience I can benefit and learn from.
Thanks for all other replies too ;)
Hi J. I do have an old 6X14 Delta lathe that I have learned to piddle with, but I'm a little bit short on IC engine know how and wany to start with something simple - if there is such a thing. Have you found that critter?
