Just wanted to get some feedback on an idea i have. Most engines we build are from drawings and sometimes casting kits. I was considering offering "CNC kits" that would be all the drawings and Gcode for an engine build. Also would include detailed instructions for setup of each operation. Unlike castings, the setup is easier because you would be starting with square blocks with edges to locate. Sometimes castings can be a little hard to figure out where to start.
The down side is that you would be stuck with the tool choices and feeds and speeds that would most likely be slow with smaller cutters so that small converted mills could be used. Also the code would be posted as Mach3 code because the vast majority of hobby operators use Mach3.
Would there be interest in something like this or am i the only one who would buy something like this.
Your thoughts please
