The First Crankshaft that I Built
esteam
Hello there,
I started to my new project called "Zeki's Twin Marine". As you see it's not only my project actually. Zeki designed it and he did a great job.
The first part that I machined is crankshaft and this is my first cranshaft machining. Here are the photos:
Embedding photos into my message is still a big problem for me. Silly me.
Erdem
Nice job on the crankshaft. I'm surprised you didn't get more chatter with cutting way out in the middle like that and without the drive pin being held tight against the drive plate.
gbritnell
If you look under each of your photos in Photobucket, there are several URLs to use. The third one, with [ IMG ] tags around it, is the one to copy and paste here.
Nice work that you do, Esteam.
The purpose of the v-blocks on each end of the shaft are to provide a reference for drilling the center and offsets on both ends of the shaft?
TIA
Jim
Erdem,
Very nice crankshaft. :bow:
Best Regards
Very nice, Erdem.
All too often crankshafts like that end up like a pretzel.
Good job :bow:
Hello guys,
Thank you for your comments.
You're right Jim. I used v blocks to drill offsets but center holes are drilled by lathe.
Erdem
