I have seen comments from respected members about using PTFE (Dupont brand = Teflon) as an insulator core for a diy spark plug insulator. Some valid comments dealt with the difficulty of machining this material, and I agree. But... Working on a video about my Tiny IC redesigned as a twin I decided to run it hard to see what would fail; after all its been sitting on a display shelf for over 10 years.
I was surprised by two things. The fun one is with some fiddling with timing and carb tuning it hit over 10k RPM. After about a minute, mostly at idle, it failed, and it turned out that the Corian insulator had burnt a bit and cracked apart.
So, since I don't mind hard to machine materials for just a few parts, are there any other reasons not to use PTFE rod?
PTFE specs say:
"While PTFE is stable and nontoxic at lower temperatures, it begins to deteriorate at temperatures of about 260 °C (500 °F), it decomposes above 350 °C (662 °F)"
versus Corian - referencing the manufacturer's website where they (very cautiously say):
"Heat resistance: the material is heat resistant up to 100 °C (212 °F), but can be damaged by excess heat. DuPont recommends the use of trivets when the material is installed in kitchens"
Both have health concerns when overheated.
Even the melting/softening/molding temps show the same 2x higher temps for PTFE.
PTFE specs say:
