steamedlou
Active Member
I picked up a Stuart triple expansion engine on ebay and await its arrival. It is my intent to have it run on steam and want to build up a display that will have the engine and a boiler. I want to make whatever use I can of what comes with the engine even if its pretty much for show. The feedwater pump on the side of the engine is obvious. ill try and use it for a feedwater pump if it has the pressure. My big question is what to do with the conderser vacuum pump. How should it be piped? I'm thinking it should have its vacuum side piped to a closed condensate receiver so the engine exhausts into the receiver and the pump pumps out of the receiver to the open air. Does this seem right from anyones experience. Do these little pumps really work? will the pressure in the condensate tank be negative due to the pump or will pressure build up. If anyone has a clue how this is supposed to work I would love it. thanks.
