It's time to put the piston in my beam engine cylinder. My casting kit is the old style matching the construction book by Andrew Smith; in it he refers to a parting tool to 'machine the (piston) packing groove'. However, I have 1" cast iron rings in my hardware kit, and the current Stuart design uses an O'ring in an 1/8" wide x 3/32" deep groove.
In the "How Slow Can You Go" thread: https://www.homemodelenginemachinist.com/threads/how-slow-can-you-go.2050/page-2#post-50628
there seems to be a running comment that iron piston rings provide more drag and thus prohibit running the engine at a slow rate. This being a beam engine, slow is the desired speed.
What's the consensus on piston sealing: packing, cast iron ring or O'ring? I plan to run this on steam as well as on air...
