Interesting side note concerning the TB6600. According to the DIY robotics crowd, most TB6600 controllers sold today and ALL controllers labeled "Upgraded", don't actually use a TB6600 chip, but instead use the slightly cheaper and much smaller (physical size) TB67S109AFTG, also made by Toshiba. The performance and specifications of these two chips are similar, but the TB6600HG does have a higher peak current rating (up to 5 A), and the TB6600HG only supports up to 1/16 micro stepping, while the TB67S109AFTG supports 1/32.
I opened the metal box of the TB6600HG I purchased from an online company here in Thailand and yep, it uses the TB67S109AFTG.
I suppose closed-loop steppers are nice if you intend to really push the limits of how fast your machine can cut through a piece of stock, where you're making such large cuts, and so fast, that your steppers are right on the edge of missing the occasional step (or micro-step). And that's great if you're in a rush to get a job done or you need to make 100 widgets as fast as your machine can go,....BUT, I'm not sure most hobbyists fall into that category. Even on the few occasions where I'm making, say 60, identical parts, no one is paying me to make them as fast as possible,...so, I can, and do, take my time. Also, my experience with my mill when I have pushed cutting feed too hard is that either my milling motor bogs down with large bits, or I break smaller bits,...but never do my motors miss a step.
