Hello people
I was started project before one month to make steam locomotive, it is not made for rails just to run around house
I have not previous experience with burners, boilers steam engines but in theory i know enough.
Problem whit this loco is that it has no power to run. So I hope that some experienced people will gave me some advices to improve it.
At beginning I worked just for joy, but now when looks so nice I would like that it has power to run.
Some spec :
burner- copper pipe OD 22mm with 3 holes for wick
boiler- steel pipe turned to approx 1.2mm thickness OD55 brazed 3 copper pipes below boiler for increasing heat conductivity mounted homemade safety valve, steam dome with plug and valve, pressure test 6 bars
steam engine- single acting; with piston valves perpendicular; two cylinders 180 deg;copper cylinder; brass piston; stroke 24mm; piston diameter 16 mm
few pictures:
I assume few problems
not enough oxygen on burner
small heating surface of boiler
lots of leakage on pistons
too big cylinders for this boiler
Please comment, all advices i respect
And sorry for bad English
Salute!
Ante
Some spec :
few pictures:
Salute!
Ante
