I need to start a woodstove top stirling engine.
We burn wood for heat but I want to improve efficiency . I want to make and pump hot water. I want to fill a tank to draw from and I want to try hydronic heating.
I need plans for an engine.
I would like about a 2 inch bore piston but I don't know the size and stroke of the displace.
The hottest spot on the stove top is about 6 inch diameter.
I have a full machine shop and foundry. I can pour 30 pounds of brass easy. So a good size flywheel is easy.
Any ideas?
Any ideas?
