Ger Beattie
- Feb 6, 2012
- 7
- 0
I work for a company that uses gas spring struts , some strusts need to be replaced and I was thinking of using the cylinder of the old struts for the cylinder of an engine as I reckon the cylinders bore would be mchined parrallel and would make a good cylinder for an engine, some of the cylinders are made from stainless steel and others are from steel. So before I get and cut open a strut I want to know if it wouls de better to use a strut made from steel or stainless steel, is stainless steel a good material material to use for an IC cylinder bore?, if not maybe could be used for a vacuum engine or sterling engine
Gerard Beattie
Ireland
Gerard Beattie
Ireland
