Rocket Man
- Nov 4, 2011
- 240
- 122
I built this Pulse Jet Engine it runs on Gasoline or Alcohol or Gas/Diesel mix. It produces 10% more thrust on 25% diesel/gas mix and about 35% more thrust on Methyl Alcohol. It starts easy at 20% thrust and can be throttled up to full power with a needle valve. Ram air from forward speed gives the engine about 30% more thurst with added fuel. I built the engine body from muffle pipe and EMT conduit. The engine has an aluminum head and fuel injection directly into the combustion chamber. The reed valves are .010" blue spring steel. I cut the reed valves with avation tin snips regular type tin snips will not work.
Static thurst is 4 lbs running on propane, 5 lbs running on gasoline, 5.5 lbs running of gas/kerosene, 5.5 lbs running on gas/diesel, 7.5 lbs running on 100% Methyl Alcohol, 7.5 lbs running on 95%/5% Alcohol/water. With 200 mph Ram Air and a second fuel tank designed to give the engine more fuel as it picks up speed its 7 lbs on gasoline and 10 lbs alcohol.
http://i43.photobucket.com/albums/e358/gary350/SR-71-01.jpg
http://i43.photobucket.com/albums/e358/gary350/SR-71-02.jpg
http://i43.photobucket.com/albums/e358/gary350/SR-71-03.jpg
http://i43.photobucket.com/albums/e358/gary350/SR-71-5.jpg
http://i43.photobucket.com/albums/e358/gary350/RV-004.jpg
http://i43.photobucket.com/albums/e358/gary350/RV-005.jpg
http://i43.photobucket.com/albums/e358/gary350/RV-006.jpg
http://i43.photobucket.com/albums/e358/gary350/RV-008.jpg
[ame]http://www.youtube.com/watch?v=s5KInr3C9vQ[/ame]
