Square cylinder with round piston steam engine
The_Paso_Kid
El Paso, Texas
This is an idea I had and decided to try it out using some square steel tubing as a cylinder and machining a round piston to fit into the square hole.
[ame]https://www.youtube.com/watch?v=EKYoPAMVf2M[/ame]
There are ports cut into the drive shaft which control the intake and exhaust cycles and the engine is capable of running in either direction.
