toad281
Active Member
I am working on a 2-cylinder steam engine build. both cylinders are double acting. Stationary cylinders with crossheads. The bore of the cylinders is 1.250 inch, and the stroke is 2 inches. I am looking for a source to get some packing for the connecting rod fitting and to use on the valve mechanism. The connecting rods are 0.25 diameter and will pass-through a brass packing fitting that has a 0.028 hole necked to .5 inches. I need advice on the packing material to use and where to get some. I see the graphite packing on granger, but I really do not need the lengths that they sell. Does anyone know place that sells short, [12 inch] pieces? I also thought perhaps a better option would be to get some vitron o-rings to fit, instead of the graphite. I bought and have installed them on the pistons, but don't know if they would work for sealing the connecting rods.I can not see a reason they would not work, but I thought it better to post a question here. I will post some pictures soon of my progress. Thanks in advance, and thanks again for all the help so far.
