Penguingeoff
- May 19, 2009
- 52
- 2
In my spare time my wife and I have a Glass studio where we fuse and Cast glass. I cast a lot of Engine parts in Lead Crystal. In the photo there is a Yamaha WRF 450 piston, Con-rod (Freelance size), Cylinder (Freelance 2 Stroke) and a Freelance Valve all out of Lead Crystal.
Why might you ask, cos I like the challenge.
Is it possible to do a complete engine in cast glass? Yes it is, but there are a hell of a lot of trials and tribulations. For instance, the firing time for the Cylinder was 3 days, Grinding and Polishing another 8 hours.
Process involved Cylinder - Wooden Model, 2 Piece Silicon Mould for Wax. Cast wax. Encapsulate it with mixture of Plaster and Silica. Steam wax out so I can use it again. Fill cavity with Lead Crystal chunks. Fire to 890 degree C. Crash cool (Open kiln) to 580 C. Fire down over 70 Hours to room temp. Carefully break plaster silica to release glass. Grind and polish using a flatbed grinder and magnetic diamond discs (down to 1200 grit) then polish with Cerium Oxide.
So far the largest piece I have cast is an Egyptian head weighing 6 Kg's, 4" thick. This was over a 10 DAY firing run.
