Hi Guys,
I have designed and built a little steam / air engine that uses electric solenoid valves instead of mechanically actuated valves so I thought I'd share the plans.
I know it's not a beautiful engine but I built it as a funtional experiment. It's also my first design and build engine.
The machine I used to make it is a Clarke CL500M. This mill / lathe was bought as an MRO machine but it is capable for small projects if you take your time.
See the links for the build..
http://www.instructables.com/id/Electromechanical-Steam-Engine/
[ame]https://www.youtube.com/watch?v=jF-BylxRDvw[/ame]
My next engine will be a gasoline electric solenoid engine, probably a hit and miss.
View attachment ICENI ELECTROMECH ENGINE - SHEET 1 OF 2.pdf
View attachment ICENI ELECTROMECH ENGINE - SHEET 2 OF 2.pdf
